11-12-2017
16:05
11:54
SantiR
11-12-2017
16:05
11:54
SantiR
My ionic is not able to charge n it only 2 weeks old
Moderator Edit: Format
03-20-2019 02:48
03-20-2019 02:48
03-20-2019 03:54
03-20-2019 03:54
03-23-2019 23:35
03-23-2019 23:35
The same process for for me and it works very well. Many thanks!
@stevenruns wrote:thanks for your great suggestion. When I received my Fitbit Ionic, the excitement turned into disappointment as the screen would be black and does not turn on. It also did not respond to connection to be charged. After phoning Fitbit Help desk, there was no solution but suggestion that I send it back to their service center 2000 miles away.
Fortunately, with you advice by connecting it to the computer, the watch turns on. What a relief. Thanks.
03-23-2019 23:43
03-23-2019 23:43
The same process for me and it works very well.
Many thanks armonmar!
03-27-2019 15:42
03-27-2019 15:42
In my case my non-charging iONIC seemed like it was never going to charge again easily. Lots of fiddling, tried isopropyl alcohol too and still had problems.
Fixed it by using my electric toothbrush and a little bit of toothpaste to clean the charging groove.
03-30-2019 15:51
03-30-2019 15:51
Hi! I tried reseting about 15 times and it's not charging. I bought it in Brazil on December. Do you have any kind of support in Rio de Janeiro, please?
Regards,
03-31-2019 15:32
03-31-2019 15:32
03-31-2019 18:32
03-31-2019 18:32
04-25-2019 09:44
04-25-2019 09:44
Try cleaning contacts with fingernail polish remover. Mine was done and I was ready to start shopping for other ones. It took two Q-tips and contacts were really dirty. It now charges great and I have my watch back
04-28-2019 19:49
04-28-2019 19:49
Hello! Welcome to our Community @Jcmendonca @Woodyone11. I'm happy to see you participating again @australopolo @GD11009 and @Woodyone11, let me help you out.
@australopolo @GD11009 @Woodyone11 I would like to appreciate your posts and suggestions for @Jcmendonca, I'm glad that after some steps your Ionic charging difficulties were resolved. @Jcmendonca same as the suggestions from previous users, I recommend you to check our help article: Why isn't my battery charging on my Fitbit device? in which you will find instructions to properly clean your device and after attempting such steps, try again a restart process on your device.
Let me know how it goes, I'll be around.
05-05-2019 00:09
05-05-2019 00:09
Thanks for that, it took a few goes but it's now alive again.
05-09-2019 12:26
05-09-2019 12:26
Thank you very much. Apparently the trick is to have it on the charger when you reset it.
@NellyG wrote:@Sharoneoo try this even if it does not look like it is charging. Put it on charge. Then restart the Ionic by pressing the left hand and right bottom buttons until the logo comes up (if it doesnt come up, keep pressed for 15 seconds), then wait 5 minutes (leaving it on the charger) and repeat the restart. Do this a few times and see if the screen comes to life. If it doesnt you will need to contact supporg - link in my signature. Let us know how you go.
05-12-2019 17:16
05-12-2019 17:16
Hello again! Welcome aboard @Dave_McCallum. Thanks for your reply and update @Summerman, I'm here to help. My apologies for the delayed reply.
I'm glad to know that your Ionic devices are now responding after trying some troubleshooting steps. Don't hesitate to contact me back if both of you have any additional questions, it will be a pleasure to help with them.
I'll be here.
05-13-2019 06:52
05-13-2019 06:52
I think that part of the problem is that the charging cable doesn't grip the watch tight enough. I have ordered a Charging Stand from Amazon. The watch snaps into the charger. I am hoping that this will do even better at charging.
https://smile.amazon.com/gp/product/B07H7YMYQG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
05-13-2019 07:43 - last edited on 02-27-2020 16:04 by LiliyaFitbit
If it was that simple the brains at fitbit would surely suggest it, or not?
05-13-2019 07:52
05-13-2019 07:52
Fitbit is not going to suggest a product that they do not make or sell. They want you to keep buying their crummy cords.
06-11-2019 00:49
06-11-2019 00:49
Many Thanks, was close to returning it and buying something else and yes... it was fully recharged!!
06-16-2019 12:24
06-16-2019 12:24
Hi @Janelouise61 welcome aboard! My apologies for the delay in responding your post.
I'm happy to know that your Ionic is charging and working the way we designed it. Please do not hesitate to contact me back if you have any additional questions or need further assistance with your device, I'll be here ready to help you.
Keep me posted.
07-01-2019 23:28
07-01-2019 23:28
Thanks NellyG, I had same issue and now it works. Do u know why was that??
07-10-2019
06:48
15:39
RicardoFitbit
07-10-2019
06:48
15:39
RicardoFitbit
This is obviously a manufacturing or design defect that Fitbit is not acknowledging. My Blaze never had charging issues with the snap in case. After my blaze screen stopped working years later, I purchased the first Iconic. It was returned within 30
days with the exact same charging issues as hundreds or thousands have reported in many forums I’ve read online. I decided to give the iconic another chance 6 months later hoping the problem was solved. Immediately after unpacking the box, I noticed the same issues on the brand new watch. When the watch still has battery power left - I have to position the cord / contact in a certain way to get it to charge, just like the first Iconic. Then when the new watch died - it was impossible to see if it was charging because the screen was dead. After 3 days - I finally got it to power up, & then could see how to position the contact/ cord for it to charge. I love my Fitbit, but this will be my last unless this is solved with a new charger solution that is reliable and works 100% of the time.
Moderator edit: Word choice
