11-12-2017
16:05
11:54
SantiR
11-12-2017
16:05
11:54
SantiR
My ionic is not able to charge n it only 2 weeks old
Moderator Edit: Format
05-06-2020 09:04
05-06-2020 09:04
05-06-2020 10:48
05-06-2020 10:48
Best Answer05-07-2020 18:12
05-07-2020 18:12
Best Answer05-17-2020 20:47
05-17-2020 20:47
To @Sharoneoo :
Thank you so much for your suggestion. It worked. I was worried my ionic finally died on me after three years of use. Im so happy it is still alive hehehe.
05-18-2020 02:25
05-18-2020 02:25
05-19-2020 06:36
05-19-2020 06:36
I tried this today after being in despair and it worked... thank you very much... life saver
05-21-2020 06:35
05-21-2020 06:35
I was about to buy a new one and I tried this and it came to live again!!!!
THANK YOU!!!
05-21-2020 06:48
05-21-2020 06:48
05-30-2020 19:11
05-30-2020 19:11
I am noticing last year that many people have had trouble with their Ionic watch not charging. I hope my message here will help everyone in 2020. Here is the case: You must play with charging cable to get the charging to work in its normal working environment. It's true. Attaching the magnetic connector takes a few seconds of fussing but no one cares about that because the watch lets you know when it is connected and charging at the upper left of the face when lit up. However, when the Ionic watch battery is dead, there is nothing to let you know that the magnetic posts are on properly. The problem is there is no small charging light on the side of the watch to tell you it is charging when the watch is off. Thus, the problem. You can fuss with the Fitbit Ionic watch all day and not get the magnetic connecter right, so the immediate reaction is to think the watch is broken. There is a work around. What you need is a light that signals the Ionic Fitbit watch is charging. The reason for the red "0" is because the battery is at "0". Here is what you do for a charging light. I have a MAXOAK K2 battery. Most people today carry a portable battery of some kind. These batteries have led lights that show the battery level. When you plug into the USB port on the battery, those LED lights start blinking as soon as you plug something into the battery USB ports. If what you plugged in is not being charged, the lights go off and you know you must fuss with the magnetic stem connector for Fitbit a little more. When the battery light stays on, then know the your Ionic watch is charging. Once completely charged, the battery light automatically shuts off on your portable battery, letting you know that your watch is charged. In this way, you can use a portable battery to plug your dead watch into. You will see the lights on your portable battery stay on when you get it right. Fitbit should have thought this over in their design. If you don't have a small battery charger, you can solve two problems at once if you buy one. You can charge your fitbit, plus you will be ready for anything else that goes dead. In summary, the whole problem is a missing charging light when the battery is dead. that is all that it is. Hope this solves it.
05-31-2020
01:17
11:52
RicardoFitbit
05-31-2020
01:17
11:52
RicardoFitbit
Sounds like fun- so much for well designed ionic!
Carl
Moderator Edit: Personal info removed
Best Answer05-31-2020 08:26
05-31-2020 08:26
Best Answer06-07-2020 03:22
06-07-2020 03:22
Thanks. This worked for me.
06-16-2020 11:44
06-16-2020 11:44
initially this did not work for me because i was following mentioned steps while my watch was attached to charging cable. It worked when i took it off charging and pressed left+bottom_right button together. To my surprise by watch was 100% charged after it started. looks like watch was getting charged while it's screen and buttons were totally unresponsive
06-19-2020 13:56
06-19-2020 13:56
Hi, I have the same issue. It's completely dead now, even after leaving it on charge over night.
Please could you assist?
Best Answer06-19-2020 15:03
06-19-2020 15:03
06-22-2020 09:26
06-22-2020 09:26
Thank you! Mine is now working!
06-22-2020 10:58
06-22-2020 10:58
Best Answer06-25-2020 21:27
06-25-2020 21:27
Change the cord but only for a genuine one, it's quite cheap.
Best Answer06-26-2020 11:22
06-26-2020 11:22
Best Answer07-09-2020 15:15
07-09-2020 15:15
Worked this evening, many thanks! 😘
