@alezi Welcome to the Fitbit family! Thanks for posting on the Ionic Board.
What do you mean by "divide"? Can you clarify your question, please?
If the heart rate sensor light is always blinking; please try the following workaround that helped me once I experienced the same:
Hope this helps. Try that out and let me know how it goes! ![]()
Best AnswerI think he/she means "device"?
I would suggest restarting your Ionic by pressing and holding the left button and bottom right button together for 15 secs.
@N8teGee I hope you're doing well! Thanks for your awesome help on this thread.
@alezi Thanks for your reply. I'm glad to hear that it is working properly now. Thanks for sharing the workaround that helped you to sort this out. Hopefully, this will help other users who might be experiencing the same.
Additionally, have you checked the Feature Suggestions Board? If you have any ideas for future features you would like to see on your Fitbit device, this is the best place for asking. Feel free to search for existing feature suggestions or add you own original one!
See you around! ![]()
