11-26-2017 19:32 - last edited on 11-26-2017 20:51 by MatthewFitbit
Just bought a Fitbit Ionic today and will return it tomorrow. It is a major disappointment.
I wish Fitbit would just come right out and tell you they want to compete with the Apple Watch and this is really not for Android phone users. This is not compatible with a major Android phone, the LG V20. In fact, when I finally found the list of compatible devices, none of the LG phones released in the past few years are listed. No idea why Fibit thinks someone willing to spend $300 for a new piece of technology like the Ionic would be using an older phone as well. This sucks and was just a big wasted of time. Fitbit's developers need to get their act together!
Mu husband offered to swap phones with me and give me his LG V30, but it is even newer than the V20 and, of course, is not supported.
11-26-2017 19:36
11-26-2017 19:36
I am using LG V30 and have no issue with the ionic (so far). What kind of issue did you experience with Ionic on LG V30?
11-26-2017 19:42 - edited 11-26-2017 19:43
It definitely works. I have a V20. I just got one yesterday and paired it easily. Maybe you missed a step?
11-26-2017 20:08
11-26-2017 20:08
@Ros-SC Have you tried setting your Ionic up. My Sony isn't on Fitbits list and I have no issues. My Pay works perfectly and all other functions work as documented.
My specs are in my signature.
11-26-2017 20:48
11-26-2017 20:48
My phone which is a way older model is not listed and stills works fine.
You should try to see if it works.
Wendy | CA | Moto G6 Android
11-28-2017 07:11
11-28-2017 07:11
Let me clarify. I was able to connect/pair the V20 easily and it synchs with the phone, and performs all of the Fitbit activity functions just fine. However, it does not do notifications correctly. Text messages and emails are hit and miss. Sometimes they came through quickly, other times they were delayed a lot or just did not pop up on the Ionic. Phone calls never came through to the Ionic. I understand these would only be notifications with no ability to reply or answer, but I expected to receive the notifications on the Ionic.
I called Fitbit support and they walked me through and confirmed all my settings and permissions were correct. They finally asked for the make and model of the phone and then told me it was not compatible. Later, after a bit of searching, I was able to find the list of compatible phones on the website and it looks to me like they do not support any of the phones LG has released in the past 2 - 3 years.
11-28-2017 07:17
11-28-2017 07:17
One more point. The reason I posted in this forum is the Customer Support representative suggested I post as a means to get feedback to Fitbit and developers about this issue.
Thanks
11-28-2017 07:27 - edited 11-28-2017 07:28
Wow, good luck with that. Users are sometimes very helpful. Fitbit reps and moderators? They'll ask if you setup your device properly. If yes, and you still have issues, remove it from your account and try again.
I've been using an Ionic with a Google Pixel (Android 8.0.0) for a while and notifications are almost non-existent on my Ionic. I still haven't found a solution.
02-06-2018 10:43
02-06-2018 10:43
I have the same issue with my LGv20.
The fitness trackers work, buy text notifications and emails are non existent. Facebook is hit and miss.
04-16-2018 18:26
04-16-2018 18:26
My fitbit ionic was working perfectly with my lg v20 then there was an update, now it does not sync. I have had it for a few months now and I can't even return it. I am so upset with fitbit!
04-30-2018 14:34
04-30-2018 14:34
Are your notifications working?
04-30-2018 14:37
04-30-2018 14:37
Same experience for me, a fellow v20 user.
04-30-2018 17:43
04-30-2018 17:43
They worked for a while but stopped!
05-03-2018 16:44
05-03-2018 16:44
I have av20 and it will not connect to the app. Gets to the numbers and sits in an endless connecting screen. Did this happen to you
05-05-2018 12:02
05-05-2018 12:02
