03-25-2019 13:11
03-25-2019 13:11
Hi all,
My Ionic stopped giving the resting heart rate and sleeping stages since last Tuesday (March 20, 2019). So far I have done the following:
- shut off and restart watch
- re-install app
- factory reset
Unfortunately it has not improved. also sometime it gives me a some random heart rate like 145 bpm just from standing up and taking a few steps 🙂
Any suggestions as to what I should try next?
Thank you in advance
Best Answer03-25-2019 15:14
03-25-2019 15:14
Check your heart rate graph to see if you are getting steady heart rate readings through the night.
The way to see the best detail of this is on the fitbit.com dashboard. Look at the wide graph with 2 drop-down menus near top left. Select heart rate and Daily.
If tracker is slipping around on your wrist to not keep good readings, that might cause those problems.
03-26-2019 16:15
03-26-2019 16:15
Indeed it seems i am heartless while i am sleeping. I will check the wrist band tonight. Thank you for taking the time to help.
