10-18-2017 16:31
10-18-2017 16:31
Does everyone realize there is no way to change or replace an ionic fitbit battery?
10-18-2017 16:36
10-18-2017 16:36
There is no way to change a battery on any Fitbit device or 99%+ of the wearables out there...... Guess I'm missing the point?
10-18-2017 16:46
10-18-2017 16:46
With many there are ways around it and many have screws and people have managed to get around the issue
Battery replacement was not possible with the Garmin phenonix 3 and as they are only screwed together people have found replacenent batteries.
They should be making them where you can replace the batteries can be replaced.
With the ionic completely sealed this is impossible.
10-18-2017 16:51
10-18-2017 16:51
Yeah, it has been fairly well documented / discussed that the battery isn't removable. Having a removable battery would pretty much negate the waterproofing feature.
https://community.fitbit.com/t5/Ionic/Is-the-battery-replaceable/m-p/2163109
