Not Able to set up Walk Cues in Ionic
Dear All,
I use a fitbit Ionic for tracking my activities. i had included Walk as my choice of exercise as i do a 1 hour brisk walk every evening after a run in the morning. But the walk is not featuring in the tracker as a mode of exercise. For Running i was able to set the cues but am not  to set up Walk cues in my Fitbit App. The following error is appearing in my App window of my smartphone.
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.fitbit.FitbitMobile/com.fitbit.device.ui.ExerciseShortcutSettingsActivity}: java.lang.NullPointerException: Attempt to invoke virtual method 'java.util.List com.fitbit.data.domain.device.AutoCue.getPossibleValues()' on a null object reference
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2754)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2815)
at android.app.ActivityThread.-wrap12(ActivityThread.java)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1554)
at android.os.Handler.dispatchMessage(Handler.java:102)
at android.os.Looper.loop(Looper.java:163)
at android.app.ActivityThread.main(ActivityThread.java:6378)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:901)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:791)
Caused by: java.lang.NullPointerException: Attempt to invoke virtual method 'java.util.List com.fitbit.data.domain.device.AutoCue.getPossibleValues()' on a null object reference
at com.fitbit.device.ui.k.c(SourceFile:67)
at com.fitbit.device.ui.k.b(SourceFile:61)
at com.fitbit.device.ui.k.<init>(SourceFile:56)
at com.fitbit.device.ui.ExerciseShortcutSettingsActivity.d(SourceFile:153)
at com.fitbit.device.ui.ExerciseShortcutSettingsActivity.onCreate(SourceFile:111)
at android.app.Activity.performCreate(Activity.java:6857)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1119)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2707)
... 9 more
Would highly be obliged if anyone can help me with a solution in regard to this.
Regards
Debamitra Basu
1 REPLY 1
@Debamitra Welcome to the Fitbit Community! Thanks for sharing the experience you are having with your watch setting up the cues for walking. Thanks for sharing the error that you are seeing.
In this case, you need to add the "Walk" activity to your Exercise Shortcuts:
  1. From the Fitbit app dashboard, tap the Account icon >  your device image.
  2. Tap Exercise Shortcuts.
  3. To add a new exercise shortcut, tap the + icon and select an exercise.
  4. To remove an exercise shortcut, swipe left on a shortcut (on Windows 10, tap the trashcan icon).
  5. To reorder an exercise shortcut, press and hold a shortcut, then drag it up or down to change its position.
  6. Sync your device.
That should certainly help you out.
Try that out and let me know how it goes! Smiley Happy
Santi | Community Moderator, Fitbit
Like my response? Vote for it! Also, accept as solution!
