02-04-2019
02:36
06:30
SantiR
02-04-2019
02:36
06:30
SantiR
Hi there,I updated my ionic (2017v) on the weekend and have not been able to access my calorie counter on my watch although I can sync on my iPhone ?? Any ideas ??
Moderator Edit: Updated Subject for Clarity
Best Answer02-05-2019 06:30
02-05-2019 06:30
@MrDoyle Welcome to the Fitbit family! Thanks for taking the time to post the situation you are experiencing with the calorie counter on your watch. I'm glad your watch is syncing correctly.
In this case, I believe this could be happening as a result of the clock face you are using. Please try changing the clock face to another one and check if that will do the trick.
Hope this helps. Keep me posted! ![]()
Best Answer02-05-2019 06:51
02-05-2019 06:51
Best Answer02-10-2019 12:20
02-10-2019 12:20
@MrDoyle Thanks for your reply and for trying those steps and sharing those details.
What is the name of the clock face you are using?
Please try downloading one of the following clock faces and let me know if you are able to see the calories then:
Try that out and let me know how it goes! ![]()
