09-29-2017 00:46 - edited 09-29-2017 00:46
My Ionic died during the night, and when I went to charge it this morning, nothing. Did not turn on, not reseting.....nothing. Has anyone else had a problem so far? Contacted FitBit support, was told to leave it on charge overnight and see what happens? Not a happy chap to say the least....
Had it for all of 48 hours....
04-26-2019 04:28
04-26-2019 04:28
Hopeless, I lost the receipt, and out of warranty, which they said cannot fix it because no receipt!!
Best Answer04-26-2019 06:34
04-26-2019 06:34
Plus all the button for over a minute, still no respires, so long fitbit!!
Please change a new name to market your stuff!!
Best Answer04-26-2019 06:35
04-26-2019 06:35
Press all buttons and no response, so long fitbit!!
Best Answer05-09-2019 19:45
05-09-2019 19:45
I am having all of the same problems! I didn’t notice my Fitbit was on low battery before I went to bed so I unexpectedly woke up this morning to it dead, it wouldn’t turn on or anything so I went to the app and that’s how I figured it was dead. I have tried the two button fix and basically tried every outlet in my house. I tried the 3 button fix and no luck yet but I will of course continue to try and hopefully something happens! I had only just received this watch for Christmas! If I reset my Fitbit will I still be able to re-sync all my information once my Fitbit is back on if it works??
Best Answer05-10-2019 05:44 - last edited on 02-22-2021 12:19 by LiliyaFitbit
Try letting it fully charge overnight on a outlet and not computer.
I hope that works!
Sent from my iPhone
05-22-2019 11:16
05-22-2019 11:16
I am having the same issue as above, i was going to get ready for bed and noticed that my watch was dead. I know i checked it a couple hours prior and it was about halfway charged. I put it on the charger, when i got up this morning my watch was still dead, no battery at all. I tried another charger for 2 hours and nothing. This is the second Ionic that i have bought with like issues. I have tried the reset and that does not work.
Best Answer05-23-2019 23:32
05-23-2019 23:32
2nd Ionic?!? Hope that they replaced a new one to you, not purchasing with a 30% discount!!
I purchased a Galaxy watch already!! A lot better!!
Funny thing was, when I bought the new watch. All the customer service found it strange that I need the receipt to get the watch fix, and even if I pay for the service, not allow me to fix the watch. Other thing, I scanned through the shop, Ionic seems disappeared at the display! Whole display window only left out Ionic, while other fitbit models, even older models were still there. Seems that's a major hardware failure, and not selling anymore!!
Best Answer07-15-2019 10:36
07-15-2019 10:36
I had the same problem and that worked for me also.
Best Answer08-17-2019 03:18
08-17-2019 03:18
well woke up had my fitbit on the charger and it was dead switched to the usb charging port on my UPS backup and still nothing checked voltage on cable checked ok spring action on pins seemed ok, switched to my computers 3.2 port still nothing
then I came here before calling fitbit and whola your tip worked not at first though I flopped the plug around and bingo it came on and after a few sec with the fitbit logo it shut off I then pushed the left button and boom it was showing 99% charge so there is still somthing going on I hope they get this fixed
thanks for the tip
Best Answer01-13-2020 05:55
01-13-2020 05:55
This really helped . Thanks a ton !
Best Answer01-17-2020 06:40
01-17-2020 06:40
Wow...thank you! I had the same issue and I thought my Ionic was dead. I tried your trick and like you said....it magically came to life. 🙂
Best Answer01-17-2020 08:01
01-17-2020 08:01
Best Answer01-19-2020 06:41
01-19-2020 06:41
My ionic is not turning on, neither is charging. It just stopped working. I have another Fit Bit watch that still works and I've had ir for a longer time than the Ionic. Not a happy camper.
Best Answer01-19-2020 06:45
01-19-2020 06:45
Did the same and it worked!! Thank You!
Best Answer01-19-2020 06:54
01-19-2020 06:54
Best Answer04-02-2020 10:27
04-02-2020 10:27
This would be less of an issue if the "magnetic" charger was half decent.
Best Answer04-06-2020 12:38
04-06-2020 12:38
Had the problem that my Fitbit Ionic would not turn on even after charging it for a week and trying every button combination possible. Somebody mentioned a fix and it was to hold down the left and bottom right button and insert it into the power supply. While that didn't exactly work, I tried taking the holding down the same buttons and taking the charger in and out of my power supply (about 5 times) until it magically turned on.
Best Answer04-06-2020 23:13
04-06-2020 23:13
No, I not working for me😢:hammer_and_pick:️
Regards
Best Answer04-06-2020 23:21
04-06-2020 23:21
I tried everything.. Hard reset with all 3 buttons as suggested on fitbit site, but I now all I see is a watch that says... In red with a big red :cross_mark_button: and data not cleared, sync & try again. But it will not sync... So I am stuck. From South Africa, no help Centre here. Watch just over 2 years old.
Best Answer04-07-2020 15:41
04-07-2020 15:41
Really simple to fix in 4 steps.
1. Do not panic.
2. Plug onto charger at back of Fitbit but leave charger turned OFF at the power point.
3. Leave like this overnight.
4. Flick power on in the morning. Fixed.
