10-04-2017 15:45
10-04-2017 15:45
For example - I'm busily texting with someone on my phone. Every time I get a text message back from them, I also get a notification on my Ionic.
I don't need to be notified if I'm using my phone, I only want the notifications when I'm *not* using my phone.
Samsung device has this option (only notify when phone is not in use), wondering if I'm just missing a setting somewhere for the Ionic. Thanks!
10-04-2017 16:59
10-04-2017 16:59
@SunsetRunner
From the clock screen on the Ionic, swipe left. You will see a screen with the battery status, "Screen Wake", and "Notifications" settings. Select the "Notifications" settings to turn notifications off. You can then manually turn them back on when you want to start receiving them on your watch again.
Best Answer10-04-2017 17:17
10-04-2017 17:17
Well.. I don't want to turn them off because then I have to turn them back on when I'm done texting. Because then I have to turn the off, on, off, on as I get text messages throughout the day. That's just kind of fiddly. There should be some smarts built in that, say, know when my phone is unlocked that I'm probably using it, and suppress notifications if phone unlocked = true.
