02-14-2018 21:12
02-14-2018 21:12
I am having an issue with the Ionic not removing notifications after I've removed them on my phone. Text messages being the most common issue. If i read a text message on my phone, why does it not clear from the notifications list on my Ionic. Other notifications exhibit the same behavior, which is not the correct way to implement notifications. They should be removed from watch when they are removed/read/whatever on the phone. Is there a setting to remedy this, or is this how the notifications are designed.
Cheers
02-14-2018 21:35
02-14-2018 21:35
I'm actually not even sure it is possible to do it on both iOS and Android.
Best Answer02-15-2018 08:07
02-15-2018 08:07
At present, clearing notifications from your phone does not clear them from your Ionic. Also, clearing them from your Ionic does not clear them from your phone. The Ionic is in its own little world.
Best Answer02-15-2018 09:20
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
02-15-2018 09:20
I also requested this, but it is not yet planned.
If enough people vote for this request, they might rethink this.
Please vote for this option, because all other smartwatches and even trackers do have this feature.
Best Answer02-15-2018 10:17
02-15-2018 10:17
How do you clear them from the watch in general? I can't get them to go away.
Best Answer02-15-2018 16:15
02-15-2018 16:15
Scroll down to the last one. Has a button to clear on the end of it.
Best Answer01-24-2019 05:02
01-24-2019 05:02
I can not clear WhatsApp messages from Ionic that someone removed from WhatsApp message board. In watch you can swipe it right or press clear to remove it but after that when you swipe from top to down to see was the notification actually removed you can see that notifications are still there. If I chose answer the message I get answer after couple seconds "Action failed this notification has expired and is no longer valid. I'm using Samsung A5 (2017) phone together with the Ionic.
