01-20-2018 12:15
01-20-2018 12:15
Hi!
I have been having lots of trouble pairing my wireless headphones to my Fitbit Ionic. Every time I try to add a new device (my headphones) through bluetooth it says that no devices were found. I have the Plantronics BackBeat FIT headphones. Anyone else having this problem? Not sure if they pair or I have to buy a different brand?
10-24-2018 17:22
10-24-2018 17:22
Try pressing your volume keys (keep clicking them for 3 seconds or something) it worked for me. And if that doesn't work then only try with the + Volume key and then the - Volume Key
01-20-2018 12:31
01-20-2018 12:31
I had no trouble pairing mine. Did you put the headphones in pairing mode while searching for devices on the ionic? Thus power-off headphones, power on and keep pushing the power on button until a female voice says "pairing". Then try to connect the ionic.
01-20-2018 12:51
01-20-2018 12:51
Got it! Thanks so much
04-20-2018 08:43
04-20-2018 08:43
Unfortunately this doesn’t work in my case. Can it be a firmware issue? I shut Down my BBFit, activated it again and went straight to pair mode. In the settings menu of my Ionic I clicked to add devices and my Ionic kept on searching without succes a couple of times, but never found the BBFit, which stayed in pair mode the entire time. And which works perfectly with my iPhone by the way. I’m starting to get frustrated with this
04-22-2018 10:57
04-22-2018 10:57
@BRueckert Welcome to the Fitbit Community! Thanks for sharing the situation you are experiencing connecting your Bluetooth headphones with Ionic. Also, thanks for trying the steps provided on this thread in order to sort this out.
I'd recommend performing a restart on your Ionic. Then, out the headphones on pairing mode and try to pair them again. This has helped other users in the past.
Also, make sure no other Bluetooth devices are nearby. They may be interrupting the signal causing the pairing process to fail. If there are any other Bluetooth devices, please turn the Bluetooth off from them.
Try this out and let me know how it goes!
05-22-2018 06:19
05-22-2018 06:19
I've tried all of the above and it still isn't working, only brought it yesterday
05-28-2018 17:11
05-28-2018 17:11
thank you Carnell ! your suggestion was very helpful & resolved my problem...
07-30-2018 07:13
07-30-2018 07:13
Do you have the Plantronics Backbeat fit? Were you able to pair with your Ionic?
07-30-2018 07:19
07-30-2018 07:19
Where you able to resolve? I tried everything, restarts, shutdowns, nothing works. So my Backbeat Fits are not compatible? I saw something about certain Bluetooth 3.0 and 4.0 EDR. Could it be that the ionic and BBFits are on different Bluetooth waves?
Please help. Someone out there ever get this to work?
10-24-2018 17:22
10-24-2018 17:22
10-27-2018 17:56
10-27-2018 17:56
Yes yes yes yes!!! Thank you! I’m running phone free! Amazing.
05-11-2019 22:19
05-11-2019 22:19
Another Solution I found in the manual and which worked for me:
To enter pairing mode after the first pairing process, start with the headphones powered off and then press and hold the Power button until you hear "pairing."
05-31-2019 11:53
05-31-2019 11:53
This worked for me to pair my Fitbit Versa to my Backbeat Fit, thanks!
06-07-2019 09:31
06-07-2019 09:31
Thank you! This worked for me.
06-21-2019 06:28
06-21-2019 06:28
Hold the power button for a few sec starting from the OFF position to enter pair mode! YESSSSSS, thank you! I couldn’t seem to find this info on the plantronics website and it helped me pair with my new Garmin. Thank you 🙏
06-24-2019 20:05
06-24-2019 20:05
Thank you. This worked. I just replaced my Backbeat headphones and was trying to pair them all night. I was going crazy because my watch wouldn't recognize the device until powered down and then held the power on button until I heard "Pairing". They don't explain that in the instructions.
06-30-2019 10:15
06-30-2019 10:15
I’m having the same issue! It’s quiet annoying trying to pair. I’m not sure if it’s fit bit or the plt bb fit 2100. Thank you requesting for a solution.
