04-20-2018 18:59
04-20-2018 18:59
How do i download stations on Pandora that I choose? If it only grabs the most listened to, then it will download the same stations over and over if that’s what is on your ionic. I thought it downloaded the 1st 3 stations listened, but I changed them, it downloaded for 4 hours and I had exactly what I started with. Any help would be appreciated?
Best Answer04-21-2018 07:44
04-21-2018 07:44
Hi @Cosmo1014,
Yes, that's the way it's designed. It uses the top 3 stations, the same as Offline Mode in the Pandora phone app. I've gone in and deleted stations before to get new ones to be the top 3, or listen to another one enough that it becomes a top 3. Hope this helps.
