11-25-2018 10:43
11-25-2018 10:43
Hi.
Over the last few days, my Ionic has decided to only hold its charge for around 36 hours. I have run a restart but it doesn’t seem to have made any difference. Is there anything else I can do? I bought it in Singapore airport in January and have the receipt and box. Thank you for your help.
Best Answer11-25-2018 11:17 - edited 11-25-2018 11:19
You could try performing a full factory reset to see if that solves the issue, be sure to remove your Ionic from you account via the fitbit app first though. This usually ensures there is no error after the reset.
11-25-2018 11:22
11-25-2018 11:22
Thanks ... I’ll give it a go, as soon as it has some charge!
Best Answer11-28-2018 16:41
11-28-2018 16:41
Thank you for replying. Unfortunately the battery is still only lasting slightly more than a day. 🤔 Is there anything else I can try?
Best Answer11-28-2018 18:12
11-28-2018 18:12
Do you have notifications enabled? If so, you may want to consider turning them off, as they will eat up battery. If it's on All Day Sync or Always Connected, you may want to try switching those options off as well.
one cruise ship at a time!
