12-29-2017 03:34 - edited 12-30-2017 19:39
[EDIT] TL;DR: If your sync seems defective, it probably is. Hope this saves some people days of frustration. They just can't seem to get the sync to work right. Unfortunately, they'll put you through endless lists of "fixes" that don't fix sh*t. (I have done EVERY fix recommended, in those long blue lists that seem to be official, and every other one I could find. Resetting sometimes helps, temporarily. Nothing else does.)
Delicate flowers should not read further...
This thing will not sync, other than once in a why by fluke. It's my second one. The first one ended up displaying red X on the screen and wouldn't do anything else.
Both of them had huge problems with syncing. They do it occasionally. I have no idea why. Just in the mood, I guess.
So many people are facing this. I think it's just wrong that Fitbit tells us to go through all these steps. I have done them. All of them.
They're time consuming and it's very frustrating.. Especially because they just don't work. I've reset these things entirely a several times, because that's supposedly the last resort that will definitely fix it. It definitely did not.. One told me that all the data hadnt' been cleared, no matter how many times I supposedly factory reset it.
The new one has also quit illuminating when I turn my wrist over. I guess it just decided it doesn't want to do that anymore.
Other tech I've used doesn't present any where near this level of hassle and frustration.
I think this is just a mass beta test.
I'd really love this thing if it worked. Unfortunately, it's more smoke and mirrors than functioning product.
Very glad I can return it. Thanks for wasting my time.
12-29-2017 06:41 - edited 01-02-2018 06:45
Each day, I have to do a hard reboot to get my Ionic to sync during the day.
Update: For the last three days now, my Ionic has been syncing flawlessly so now, the only thing that doesn't work is the weather app. I can live with this.
12-29-2017 09:49
12-29-2017 09:49
Read this rant, saw nothing to even base a fix off as this doesn’t work and that doesn’t work means absolutely nothing.
Wishing for my wasted time back....
Best Answer12-30-2017 19:39
12-30-2017 19:39
Just the sort of hassle I want to be paying $300 for....
