09-27-2017 13:19
09-27-2017 13:19
How in the heck do you get the bands to lock back into place? I have taken them off and they wont lock back into place. It looks like you just insert and it should snap into place, but mine is not snapping at all. It is almost like the pins have stayed retracted.
09-27-2017 14:33
09-27-2017 14:33
@racertempo We have a helpful video tutorial on how to put on and remove bands from Ionic. Check it out and let me know how it goes!
09-27-2017 14:33
09-27-2017 14:33
09-27-2017 15:47
09-27-2017 15:47
I had this - just had to push them in extra hard and eventually they snapped in correctly
09-27-2017 16:44
09-27-2017 16:44
@Benood wrote:I had this - just had to push them in extra hard and eventually they snapped in correctly
Thank you both, I did finally get it.... like you said, push really hard and even a tiny wiggle while doing it. Thanks!
07-14-2018 12:55
07-14-2018 12:55
Thank you all. I was getting crazy trying to reattach it, so it was only a matter of pushing harder.
