08-28-2018 00:47
08-28-2018 00:47
I just noticed that my red sensor light was on for a while today. Looks like the SPO2 sensor might be activated soon.
Best Answer08-28-2018 07:35
08-28-2018 07:35
Don't hold your breath!
08-28-2018 07:57
08-28-2018 07:57
@SunsetRunner Literally ![]()
Best Answer08-28-2018 08:26
08-28-2018 08:26
Both my Ionic and Versa have been doing this for a long time. The red LED is activated when you go to sleep and it turns off just after you wake up.
I heard someone post that it's used for more accurate sleep stages, whether this is true or not I don't know.
08-28-2018 09:56
08-28-2018 09:56
Hey guys @MattJ71, @Cantryboy, and @SunsetRunner, thanks for stopping by!
In regards to the red light, as my friend @N8teGee mentioned, the optical heart rate turns red during the tracking of sleep and changes to green shortly after the customer is awake. This is an expected behavior!
Hope this clarifies your inquiry, let me know if you need further assistance!
08-28-2018 10:20
08-28-2018 10:20
So I just had a long chat with support and it said that the ionic specialists could not yet tell us what the red light sensor does or when the red light sensor's mysterious/unknown function will be enabled.
Can someone please clarify what the red light sensor does and when it will be enabled?
Best Answer08-28-2018 10:24
08-28-2018 10:24
Kate, Customer Support is the LAST word around here.
08-28-2018 10:30 - edited 08-28-2018 10:31
Hey @SunsetRunner, thanks for jumping in here! As I mentioned above, the optical heart rate turns red during the tracking of sleep and changes to green shortly after you are awake. ![]()
08-28-2018 10:33
08-28-2018 10:33
HI Marre - thanks. So when I am awake there is no difference in the accuracy of the fitness monitoring between the Ionic and the Alta HR. It is the same technology and even once the red light sensor is enabled on the IONIC, it will ONLY turn on at night and never during the day. Is that correct?
Best Answer08-28-2018 10:42 - edited 08-28-2018 10:42
You're welcome @SunsetRunner! If you're talking about the red light during the day, so you're right. Only the green lights will be working to detect your heart rate throughout the day.
I'd recommend taking a look at the article: What should I know about my heart rate data?
Let me know if you need further assistance!
08-28-2018 12:28 - edited 08-28-2018 12:31
@MarreFitbit wrote:Hey guys @MattJ71, @Cantryboy, and @SunsetRunner, thanks for stopping by!
Well, the RED light was on during the day today when I was fully awake. I just happened to check it and it was flashing GREEN and RED.
I've had my Ionic since launch day and have NEVER noticed it before.
Best Answer08-30-2018 09:05 - edited 08-30-2018 09:05
Thanks for reporting this @MattJ71! I'd recommend restarting your Ionic as this should only happen when you're asleep. Here are the steps for the restart:
Hope this helps, I'll be around if you need anything else!
09-09-2018 22:42
09-09-2018 22:42
Morning all.
@MattJ71 - just noticed my Ionic (whilst taking it off to charge) had both RED and GREEN lights flashing at the same time - first time I've ever noticed this, and I too have an Ionic since launch.
Bizarre. Just thought I'd share. Is yours still doing this?
Best Answer09-10-2018 03:34
09-10-2018 03:34
@SunsetRunner wrote:Morning all.
My Ionic and Versa do it every night, they revert to green only soon after I get up.
09-10-2018 07:14
09-10-2018 07:14
After weeks, I can confirm that the RED and GREEN flash when I'm sleeping. Shortly after I get up (after a few minutes) only the GREEN flashes. Fitbit is definitely activating the SPO2 sensor at night... perhaps testing...
03-30-2019 19:56
03-30-2019 19:56
It's been months since the last post in this thread. Does anyone have a solid answer? Fitbit staff, where are you? I know the red/amber LED light is normal when sleeping...I get that. My question is WHY? What's it doing when it's red/amber? Please make a statement on this.
Best Answer04-18-2019 02:41
04-18-2019 02:41
It's a method that can be found in most hospitals and has been used in the medical industry for tests like pulse oximetry, which measures oxygen levels in the body. The body is a poor absorber of red light allowing the light to pass much deeper into the body and a larger volume of tissues to help provide more insightful data and could lead to improved accuracy with biometric data like heart rate.
Using a combination of red and IR wavelengths can be used to assess SpO2 (blood oxygenation) when worn at the finger, forehead, or ear, and to assess muscle oxygenation when worn at the wrist, arm, or leg. Moreover, using IR light can help with reducing sunlight noise (the sun generates a much higher percentage of green light than IR light), helping folks sleep at night (no green light glow in bed), and with helping to remove motion noise from signals
Needless to say, it's used to get the blood oxygen (aka SpO2). Though, as most (and me mostly noticed) the combination of red and green lights are only mostly triggered/enabled while asleep, or when waking up.
Best Answer04-19-2019 16:15
04-19-2019 16:15
Yes @Skyrider but what is Fitbit doing with it? There is no such feature.
Best Answer07-26-2019 10:44
07-26-2019 10:44
Mine just turned on and won't turn off? It's 11:41 am. Also my sleep tracker hasn't worked these last few days? And the battery dies after just 1 day? Any thoughts?
Best Answer08-12-2019 18:51
08-12-2019 18:51
Exactly the same here
