09-23-2017
18:25
20:14
09-23-2017
18:25
20:14
I posted this in another thread but thought I'd also make a seperate post just for this subject so we can all share where to get accessories for the Ionic.
☆ Bands ☆
Solid Stainless Steel $21.99 / Free Shipping
Comes in rose gold, gold, silver, and black.
Magnetic Milanese Loop Stainless Steel Replacement Bands $11.88 - $12.88 / Free Shipping
Colors are: Black, Silver, Gold, and Rose Gold, Rose Gold w/ Rhinestones. There are some that you can remove the links without a tool.
☆ Full Body/Screen Protector ☆
Skinomi TechSkin Full Coverage + Screen Protector $12.95 + $3 Shipping
Those are just a few for now.
& If anyone wants to add to this thread, for any other accessories they find. So we could just come on this thread to look what others have posted and we don't have to keep searching all across the web. It would be super helpful and appreciated!
10-07-2017 11:48
10-07-2017 11:48
Has anyone recieved any accessories for the Ionic? If you did, how do you like it?
Best Answer10-07-2017 12:21
10-07-2017 12:21
I received my Skinomi protectors. Decided to run it naked for now as I like the look and feel of the glass. I'm kinda leaning towards the way of leaving it like that.
10-07-2017 12:49 - edited 10-07-2017 12:51
Are there protector available that do not only protect the glass, but the case as well?
I'm more concerned about the case. If I understood well the glass is very hard.
Replacement bands not yet available here, the are expected in a week or so.
10-07-2017 13:46
10-07-2017 13:46
Got my Milanese loop band today
Time will tell how long it lasts.another one coming soon, this one shipped within 3days amazon
10-07-2017
17:24
08:15
JuanJoFitbit
10-07-2017
17:24
08:15
JuanJoFitbit
Yes @FastEddy- there are some options.
that goes on the screen and frame
It fits around the frame and acts as a bumper for the screen. It also comes in different colors or just plain clear.
Best Answer10-07-2017 17:29
10-07-2017 17:29
@CopperWolf808 wrote:
Yes @FastEddy- there are some options. You could get aFull Body + Screen Protector that goes on the screen and frame or a Ionic Case That goes around the frame and acts as a bumper for the screen. It also comes in different colors or just plain clear.
I ordered the Ionic Case that you mentioned in clear, as well as a rose gold milanese band. They should be arriving tomorrow. I have the burnt orange Ionic, and do not want to hide the beautiful color of it, but also want to try to protect it. I am not too worried about the screen with it being gorilla glass.
10-07-2017 17:33
10-07-2017 17:33
@SunsetRunner does the band lock into the body well? Clicks in securely?
Best Answer10-07-2017 17:37
10-07-2017 17:37
Yes @FastEddy- there are some options. You could get aFull Body + Screen Protector that goes on the screen and frame or a Ionic Case That goes around the frame and acts as a bumper for the screen. It also comes in different colors or just plain clear.I ordered the Ionic Case that you mentioned in clear, as well as a rose gold milanese band. They should be arriving tomorrow. I have the burnt orange Ionic, and do not want to hide the beautiful color of it, but also want to try to protect it. I am not too worried about the screen with it being gorilla glass.
I am going with the clear case too. I still wanted the color of the frame to show through too.
10-07-2017 22:25
10-07-2017 22:25
Yep. There is a slight gap, but I’ve pulled it and doesn’t come off. Fun fact you can remove the Milanese loop since it uses the standard 22mm bars used in pebble time. So any 22mm bands work. Currently have my pebble time steel band with my ionic
10-07-2017 22:40
10-07-2017 22:40
I tried one of those magnetic bands with my Charge 2, and it simply wouldn't hold my device in place whenever I wore long-sleeved garments -- putting on a jacket, for instance, meant knocking the Charge 2 off of my wrist. So, I would appreciate any comments about how well the magnetic bands have been working.
Meanwhile, I have the Charcoal / Smoke Gray Ionic, and while I believe it has the darkest-colored band, I find it far too conspicuous. So, I purchased a rather plain black band, made of similar materials with a similar clasp, from Amazon. I'm exceedingly happy with it -- it makes the Ionic seemingly less noticeable on my wrist, and it actually fits better than the OEM band -- its holes simply are spaced better to fit my wrist. Very happy with what was a ten-dollar investment.
10-07-2017 23:01
10-07-2017 23:01
@SunsetRunner Can you link the band that you got? I want a black band. I thought the band we got was going to be darker.
Best Answer10-07-2017 23:08
10-07-2017 23:08
@SunsetRunner I had a milanese loop band for my Blaze, the magnet on that one was very strong. I would hope the same of the Ionic one, maybe you had a faulty one for your Charge 2?
23:21
08:38
MarcoGFitbit
10-07-2017
23:21
08:38
MarcoGFitbit
Here you go:
Not really any difference from the OEM band in terms of materials, quality, and design, from what I can tell. Just a simple black band. Also, Amazon Prime shipping was a requirement for me, which was part of why I chose this one.
Moderator Edit: Removed Advertising Links
Best Answer10-07-2017 23:24
10-07-2017 23:24
@N8teGee wrote:@SunsetRunner I had a milanese loop band for my Blaze, the magnet on that one was very strong. I would hope the same of the Ionic one, maybe you had a faulty one for your Charge 2?
I'm not even sure what brand name my band was -- I'd have to go slogging through some old records. The magnet held quite well while wearing it, but whenever I tried to put a jacket on or take it off, I would always dislodge the band to the point where I'd have to take the jacket off, put the Fitbit back on my wrist, and try, try again. I didn't put up with that for very long.
04:31
08:10
RobertoME
10-08-2017
04:31
08:10
RobertoME
I field tested this one for two full days. And it did work as it should. I reviewed it on amazon, giving it 3 out of 5 stars. The so-so review was more about the comfort and look of the band, it did function as it should and protected the Ionic. There are other reviews that give it a good rating.
Moderator Edit: Removed External Link
10-08-2017
06:10
08:14
JuanJoFitbit
10-08-2017
06:10
08:14
JuanJoFitbit
Hey @SteviK, I found this other one like that but it's $49.99.
Oh and I did see your review a few days ago and was thinking, hey thats Stevik! lol
10-08-2017 06:27
10-08-2017 06:27
@CopperWolf808 wrote:Hey @SteviK, I found this other one like that but it's $49.99.
Resilient Protective Case with Strap
That looks like the same one but WAY overpriced. lol.
Best Answer10-08-2017 06:30
10-08-2017 06:30
@SunsetRunner wrote:Got my Milanese loop band today
Shipped from China? Where are you located and how long until you received?
Best Answer10-08-2017 08:32
10-08-2017 08:32
This Milanese wasn’t shipped from China as far as I’m concerned.
Best Answer10-08-2017 10:12
10-08-2017 10:12
Here is the clear protector. It looks pretty good. I feel better now that it's protected. I'll take a photos with the rose gold milanese band later. 😊
