Not for the first time...I’ve been on a run only to find that Fitbit has split it into two separate activities- although I’ve been continuously active.
It seems to happen after the first 0.5 mile.
Any thoughts or is there a way I can consolidate the ‘different’ activities?
Thanks!
Best AnswerHello @Liam183 , may I ask which mode are you using to track your room?
Are you using the manual mode called "Run", with the resulting map showing?
Are do you let Fitbit decide what you are doing, and never set the tracker to record the Run?
Thanks @Rich_Laue - if I’ve understood your question correctly- yes, I’m manually starting the run rather than letting Fitbit decide.
It’s usually fine, but just occasionally splits the activity into two, usually resetting after 0.5 miles.
Hope that helps!?
