05-10-2018 17:54
05-10-2018 17:54
My Ionic hasn't uploaded a run to strava for the last 2 days nor has it uploaded a workout to myfitnesspal. Is there something going on? Is it a quick fix that I don't know about? It was syncing just fine until Monday (5/7/18).
Best Answer05-10-2018 20:21
05-10-2018 20:21
Ionic will only sync to Strava if the run uses GPS (really annoying limitation). You also need to authorize it in the app configuration in the fitbit app. Randomly the app will unauthorize (typically when it updates, you update the fitbit, or the wind blows form the east) needing you to re-authorize it.
Best Answer05-11-2018 05:15
05-11-2018 05:15
