04-02-2020 05:49
04-02-2020 05:49
The time was off by an hour and 15 minutes so I went to the settings screen and shutdown the watch that way. Now it won't come back on. If I leave it on the charger, the logo shows up, but it disappears shortly after I remove it from the charger. It won't do a restart or factory reset using the buttons even on the charger.
Best Answer04-02-2020 11:59
04-02-2020 11:59
Hi, have you tried to hold down all 3 buttons for at least 30 seconds to see if this will make it restart?
Best Answer04-02-2020 12:33
04-02-2020 12:33
Several times. The Fitbit logo randomly pops on the screen, but everytime I try to do the factory reset sequence, it just does again. I contacted support, and they're sending me a replacement.
