01-19-2018 17:33
01-19-2018 17:33
Just noticed on my Ionic that it is recording that I was awake and asleep during the same time period. In my opinion it is humanly impossible to be awake and asleep at the same time.
Best Answer01-26-2018 13:03
01-26-2018 13:03
It's great to see new users around @GaDuffer!
This sounds pretty odd, in order to further investigate could you please take a screenshot and post it here? In the meantime I recommend performing the restart and keep an eye on it.
Catch you later!
01-26-2018 13:03
Best Answer01-26-2018 15:53
01-26-2018 15:53
Here is the screenshot you asked for.
Best Answer01-26-2018 15:55
01-26-2018 15:55
Did the restart but didn’t fix problem
Best Answer01-26-2018 21:16
01-26-2018 21:16
what you show is a normal sleep cycle. The short awake spikes means you probably just momentarily woke up and turned over. These short instances are usually not remembered in the morning.
Best Answer01-27-2018 02:54
01-27-2018 02:54
Understand that, but doesn’t change fact that recorded times say I was awake and asleep at the same time. Doesn’t give me much confidence in accuracy of data.
