09-02-2017 14:09
09-02-2017 14:09
Does the Ionic counts stairs climbed or was that feature eliminated in order to make it water resistant?
Best Answer09-02-2017 14:28 - edited 09-02-2017 14:29
counts flights, has an altimeter built in.
What activity can Ionic track?
Ionic will track all of the following:
Can I wear Ionic while swimming?
Fitbit Ionic can be worn in the pool up to 50 meters, and will track swim workouts with stats like lap counting, duration and calories burned.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
WmChapman | TX
Best Answer09-03-2017 12:53
09-03-2017 12:53
Will it track steps a stair climbing machine? The other Fitbit devices don't.
Best Answer09-03-2017 13:07
09-03-2017 13:07
No altimeters measure a change in pressure - takes about 9 feet for a flight.
Will record each step as a step though as long as your tracker arm is swinging freely.
WmChapman | TX
Best Answer09-03-2017 13:10
09-03-2017 13:10
That's a bummer. I was hoping there would have been a change in the technology that would allow them to accurately count steps on a stair climbing machine. Thanks all the same.
Best Answer09-03-2017 20:11
09-03-2017 20:11
@ali_baba7 wrote:That's a bummer. I was hoping there would have been a change in the technology that would allow them to accurately count steps on a stair climbing machine. Thanks all the same.
I'm not sure a change in technology would work short of using a very large inertial navigation system used in modern military jets and submarines, and even those systems are not 100% accurate.
Best Answer09-03-2017 23:08
09-03-2017 23:08
I'd think it would count the steps as long as your arm is free moving.
But it won't count " floors"
Best Answer02-24-2018 16:36
02-24-2018 16:36
Wouldn’t the stair climbing machine track this?
Best Answer08-01-2019 19:10
08-01-2019 19:10
Mine doesn't count stairs - and by that I don't mean its zero or inaccurate - I mean it doesn't even have it listed as a feature and I cant figure out how to add it. Couldn't find it in the app either. My blaze had this feature this one just has steps, hours of activity, pulse, etc. Resets do not help. How can I load this?
Best Answer09-10-2019 04:28
09-10-2019 04:28
What am I missing? My Iconic does not properly track stairs. There was no solution provided in the response but rather a rehash of what the Iconic can do. I live in a two story home with 14 steps and it has recorded very few of the steps I routinely climb every day.
Best Answer04-26-2020 16:19
04-26-2020 16:19
Mines has stopped counting flights of stairs suddenly it's on the latest firmware too. Worked last Wednesday 4-23-20 the next day till now has not worked even after using assisted gps for a run
Best Answer04-27-2020 10:00
04-27-2020 10:00
Not to my experience, I've tried it many times before. Charge 2 and now the Ionic
