Why are my daily steps not showing on ionic screen, I only took it off for an hour to charge it and now the step count has gonSteps should be in the top right corner
That looks like a custom watch face so the problem may be with the app not the watch, try using a different watch face and see if the step again show (use a fit bit created one first to test then go find another if you like)
