10-05-2017 18:49
10-05-2017 18:49
Hello,
I'm a Registered Nurse and looking to buy the Ionic. I just want to ask if there's a clock face available for this watch that has a second hand or a stopwatch that stays on for at least a full minute in order to count my patients' pulse rate and respirations. I believe the Blaze had a stopwatch function that stayed on for a minute, and I'm wondering if they also have it available for the Ionic. Thanks.
Best Answer10-05-2017 21:09
10-05-2017 21:09
As of today there is no clock face of what your asking for. There is also no way to manually keep the watch on unless you constantly press the button or shake the watch.
All watch faces as of today are made by fitbit
Best Answer10-05-2017 21:33 - edited 10-05-2017 21:37
I have the Ionic and it has a TIMER function with a countdown timer.
You can set it for 1 minute but it keeps turning off the screen every about 10 seconds which if you twist your wrist turns back on another 10 seconds.
It does vibrate when the 1 minute is up even when the face is off.
There is watch face that has a second hand, but once again the screen turns off then you have to twist your wrist to get it back on. Might become annoying to you as a nurse.
Best Answer10-06-2017 02:11 - edited 10-06-2017 02:18
There is a face clock with integrated stopwatch.
It’ss stay on longer than two minutes, its stay on all the time
10-06-2017 10:26
10-06-2017 10:26
Does it really stay on when using the stop watch? That would be awesome since that’s the only thing stopping me from getting the ionic. If so, does it dim out when you stop the stopwatch? Thanks for the input.
10-06-2017 11:32
10-06-2017 11:32
Just tried stopwatch clock face. Backlight stays on while stopwatch is running. It turns off shortly after stopwatch stopped. Basically it’s exacty what you want.
05-19-2018 17:49
05-19-2018 17:49
Sonfar its the only clock I’ve found that found that works for more than 10 seconds.
