09-28-2017 13:26
09-28-2017 13:26
I'm so excited that my Ionic should be waiting for me when I get home. I have a Blaze now. My question is: when do I switch devices? If I go home and set up my Ionic, will the steps counted on my Blaze be erased for today? Or should I set up the Ionic and have it ready to go tomorrow morning so that the Blaze tracks my sleep too? I'm trying not to lose any data. Thank you!
Best Answer09-28-2017 13:29
09-28-2017 13:29
You don’t have to delete the Blaze from your account, you can have the two active at once. Just go ahead and set up your Ionic and you’ll be good to go.
09-28-2017 13:34
09-28-2017 13:34
The main thing to remember when switching between devices is to be sure to sync BOTH trackers when you switch. Ideally make sure they both say the same number of steps on the tracker itself (not just on the app). If you forget it is not a huge deal, but you may lose a few hundred, or even up to a few thousand steps.
