10-04-2017
13:09
20:14
DavideFitbit
10-04-2017
13:09
20:14
DavideFitbit
The battery lasts less than a day. I don’t use GPS that I know of. I don’t use WIFI connection that I know of.
Could I make sure WIFI and GPS are off?
Best Answer10-04-2017 14:45
10-04-2017 14:45
@Enbleu Thanks for dropping by! One hour seems a bit odd. To ensure that you maximize your Ionic's battery life, make sure you're charging your Ionic fully can take up to 2 hours. Also, check out these battery saving tips. Hope this helps!
Best Answer10-04-2017 15:12
10-04-2017 15:12
15:18
20:14
DavideFitbit
10-04-2017
15:18
20:14
DavideFitbit
If you swipe to your left (battery status) do you see a headphone icon? The ionic thinks that it connects to a Bluetooth headphone when using Ionic classic connection (to control music on your phone). My Ionic was draining really fast. I turned off the Ionic and restart to fix this issue. Hope it helps.
Best Answer10-04-2017 15:27
10-04-2017 15:27
