08-05-2018 21:27
08-05-2018 21:27
I have been using Ionic almost a month. It does work well, but the problem now is the screen does not turn on when I move my wrist. Instead, it turns on if I tap the screen.
How can I make it to turn on when moving my wrist?
Thank you.
Best Answer08-06-2018 01:54
08-06-2018 01:54
Check that the auto screen on hasnt accidently changed on the watch (it does happen!). On the watch screen give a long press of the left button to see what the watch setting for Screen Wake. Let us know if that solvesvthe problem.
Helen | Western Australia
08-06-2018 02:04
08-06-2018 02:04
I'm having the same problem. Any suggestions would be gratefully received.
Best Answer08-06-2018 07:30
08-06-2018 07:30
Just follow the instructions in the post just above yours.
08-06-2018 14:32 - edited 08-06-2018 18:03
Then hold your forearm somewhat to horizontal and rotate the wrist 90°
Best Answer08-06-2018 17:40
08-06-2018 17:40
It does work well now. Thank you for your help.
