I've been using different face clocks and at first was ok but now the time is never right I'm like about 5 hours behind os anyone else having this problem in the UK :united_kingdom:? The time is correct on my watch before anyone suggests that. How can or can you change the time on the iconic?
Best AnswerDo you mean tne time is correct on your phone (rather than watch)?
You cant directly change the time on my Ionic - just by syncing. If the time wont come right afer syncing, try restarting the Watch and sync again. If it is still not right, go to your settings and check the time zone. If the time zone is right, change it, sync, and then reset it to the correct one and sync again and see if that does it.
Let us know how you go.
Helen | Western Australia
