10-22-2018
11:59
06:44
10-22-2018
11:59
06:44
Hi all
I did a weight based class tonight and set the data screen to time, calories and HR , however when i downloaded it to the Fitbit dashboard it shows as a Run which also has a pace of 89.9 albeit on the watch it has 0 average pace
any help why the watch says weights in the history and the download a run ?
regards
douglass
Best Answer10-23-2018 06:53
10-23-2018 06:53
Hey there @douglass, thanks for stopping by! While reading your post I was wondering how you tracked your activity? Did you use the Weight shortcut on your Ionic? Did you use SmartTrack? Is this the first time your Ionic tracked a different activity?
So, in order for both of us to figure out where the issue is coming from, would you like to post me your Activity History (click here to go there). See my activity history below (I'm posting the picture I want from you):
I'll be around, keep me posted!
Best Answer10-24-2018 06:34
10-24-2018 06:34
@MarreFitbit wrote:Hey there @douglass, thanks for stopping by! While reading your post I was wondering how you tracked your activity? Did you use the Weight shortcut on your Ionic? Did you use SmartTrack? Is this the first time your Ionic tracked a different activity?
Hi there
Hopefully the pics came out ok
The exercise was done via the weights shortcut on the ionix
Best Answer10-24-2018 06:41
10-24-2018 06:41
date was the 22nd of oct
I can only imagine the steps count was the bench press and or biceps curls ?
cant see why the pace was even 89.25 lol
I also noticed again today for the second time, the first being unsure if it was me ? but now its confirmed to be the watch, I have set up each exercise that I do ie run, bike and weights to how I want the data screens but somehow twice the running one has returned to the default setting. the only data I used was- top -time elapsed, middle -distance and bottom- pace however the middle had everything ticked which I had previously unticked twice, I haven't looked at the bike or weights yet to see if this reverted back yet
Best Answer10-24-2018 06:45
10-24-2018 06:45
Ha its just done it again reverted back minutes later
