Hi @jfgarciamex and @ARGM,
One of the first apps released in the new app store is a drink counter you use on the Ionic, without needing the app. It's called Drink Counter, and is in the Utilities section of the store. Hope this helps.
@WavyDavey do you know if that app syncs with the water consumption in the app or the dashboard?
@SunsetRunner wrote:@WavyDavey do you know if that app syncs with the water consumption in the app or the dashboard?
Doesn't look like it. Seems more of an alcohol tracker.
Best AnswerMany people have asked for both the ability to track alcohol and water on the wrist.
The drink counter does both. Then at night it is fairly easy to transfer the water to the Fitbit app.
@Rich_Laue wrote:Many people have asked for both the ability to track alcohol and water on the wrist.
Yes but the salient point is that it does not sync with the Fitbit app, the main feature required by people, as noted above, when tracking on the Ionic.
Being able to sync with the Fitbit app would be an important feature. It also looks like that app only measures per glass, I would need to be able to enter the volume in ml as the glasses and bottles I use during the day vary in capacity.
Glass is 250ml hence the old 8 glasses per day formula for water consumption.
There are now two apps for the ionic that do input water consumed into the users Fitbit account.
Ionic Water
Water Logged
Best AnswerYes both are apps that run on the Ionic and are designed to enter the water consumed.
Best AnswerYes but how do you enter the information, I am using ionic water on versa...I see 3 bottles of different sizes but it doesn't do anything. I have tried clicking on the bottle size but nothing...how do I log? it would be very convenient to just click the bottle and log that amount of water
