01-18-2019 21:00
01-18-2019 21:00
Has anyone had this problem?
I have been frustrated to find that the playlists I've transferred to Ionic from iTunes were not copied in the order they were stored in iTunes. (I am a running geek and have them in order of increasing BPM.)
I've deleted all music, recopied, made sure to check the 'copy to play order' option, checked the correct advanced prefs in iTunes, etc. Then spent over an hour on hold/with FitBit support to no avail. Is there something I can do to fix this?? Totally frustrating.
There are about 30 songs, wonder if that is too many for it to handle, even if it is not 'full'?
01-18-2019 21:21
01-18-2019 21:21
@Sakaro wrote:Has anyone had this problem?
Yeah the WIFI playlist transfer process is randomly wacky. It reorders at will. Last time transferred 2.3GB filling the storage with 3 playlists. The last one took 4 attempts before all the songs were installed. Each time requiring 3 hours per attempt. Total time was over 12 hours.
Comparatively on my Apple or Android devices 2.3GB takes 2 min or less to sync or drag and drop with no errors. Every time. So concluded the Fitbit WIFI method is complete crap. And actually dread ever to put music in the Ionic ever again. Interestingly most users never even put music in -> because they simply cannot.
But would have thought 30 songs to be pretty straightforward. Mine is equivalent to about 300. Unfortunately have found no way to fix this software bug. But maybe in some random chance they will eventually go in properly if you try enough different ways. I gave up and was just happy all my songs went in -> even in the improper order.
