10-09-2017 04:24
10-09-2017 04:24
My ionic has stopped waking up when I turn my wrist to view the time. I have to push the button on the left to be able to wake up the watch. I don't see any options under settings to turn that feature on or off, am I missing something? Connected to SG7 phone.
01-27-2019 08:30
01-27-2019 08:30
Your right. There is on right swipe. Left takes you to settings which strangely has nothing (lol although I did find some fun stuff there).
You need to hold the left button (can be done from any screen). If you are playing music on your phone it will open the music control for your phone music. Then right swipe and you get to change
“screen wake” from “manual” to “auto”.
No music then no swipe required to get to screen, just hold button.
Also can also turn off notifications here.
Best Answer01-27-2019 08:45
01-27-2019 08:45
@Goetz @Chilly_C @TomCan2 @chris0531 @mkely1972 @Pacman84 @Mfrisz @Peterkaren @Woodsie61 @Bill-V Welcome to the Fitbit forums! Thanks for taking the time to share your input, help, workarounds, and experience on this thread regarding the Screen Wake feature of your watch. Also, I'm glad to read that most of you already reported that this is resolved.
If you are still experiencing trouble with the Screen Wake; please do the following in order to sort it out:
This should certainly help you out with this.
@Backintm I hope you're doing well! Thanks for sharing your help on this thread!
@etc22 I'm really glad you found this thread to be helpful.
@Pescho33 Thanks for sharing the experience you have had with battery power when turning off the Screen Wake option.
Keep me posted! ![]()
08:51
18:11
SantiR
01-27-2019
08:51
18:11
SantiR
Thanks
Much more concise then my ramblings
Regards
Moderator Edit: Personal Info Removed
01-27-2019 09:02
01-31-2019 18:12
01-31-2019 18:12
@Peterkaren @Bill-V Thanks for your replies and for confirming that this is sorted now. I'm really glad to read you are back on track now. Hopefully, this will be helpful for other users too.
Also, take a look at the Discussions Board as you will find a lot of interesting things there. Feel free to post on any thread you want. If you are looking for Fitbit friends to compete with on challenges, check this thread to add some!
See you around! ![]()
Best Answer02-03-2019 23:14
02-03-2019 23:14
I can only swipe right to left in the home click screen. Does t acknowledge swiping the other direction to get to this setting
Best Answer02-04-2019 00:46
02-04-2019 00:46
02-04-2019 08:25
02-04-2019 08:25
Thank you!!! Problem solved
02-06-2019 06:54
02-06-2019 06:54
Swiping right while the clock is displayed does absolutely nothing at all. Now what?
Best Answer02-06-2019 07:27
02-06-2019 07:27
Assuming you are looking for Screen Wake setting, do a long push of left button and you will find it there. You are correct, swiping right does nothing.
02-06-2019 07:43
02-06-2019 07:43
Best Answer02-06-2019 21:11
02-06-2019 21:11
02-07-2019 00:00
02-07-2019 14:14
02-07-2019 14:14
Where do I find the "turn on/off the quick view?"
I jsut switched from a Garmin to the Ionic and this interface is kind of a mess compared to the Garmin.
Best Answer02-07-2019 14:17
02-07-2019 14:17
You could read the posts earlier. But, a long press of the Back button will get you the Screen Wake setting.
02-07-2019 14:18
02-07-2019 14:18
02-07-2019 14:36
02-07-2019 14:36
02-11-2019 12:57
02-11-2019 12:57
@cbr_bow @Backintm Sorry for the delayed response. I hope you're doing well! Thanks for sharing the workaround to get this sorted. I'm sure this will help other users experiencing the same.
@Bill-V @Peterkaren @SunsetRunner @BrendoTheKing @Mfrisz I hope you're doing well too. Thanks for your contributions on this thread. I'm sure that new users reading this will know the steps to take to get this sorted.
I will leave the steps on this post for any other users experiencing this situation:
Hope this helps. Keep me posted! ![]()
Best Answer02-27-2019 17:49 - edited 02-27-2019 17:53
Swiping right doesn't work any more. Now you need to hold down the button on the left side of the Ionic for the screen wake option to come up.
18:08
06:45
02-27-2019
18:08
06:45
I bought a replacement and it works.
Moderator edit: removed personal information
