10-09-2017 04:24
10-09-2017 04:24
My ionic has stopped waking up when I turn my wrist to view the time. I have to push the button on the left to be able to wake up the watch. I don't see any options under settings to turn that feature on or off, am I missing something? Connected to SG7 phone.
03-23-2019 00:07
03-23-2019 00:07
03-23-2019 02:02
03-23-2019 02:02
03-23-2019 02:07
03-23-2019 02:07
03-23-2019 02:25
03-23-2019 02:25
03-23-2019 02:27
03-23-2019 02:27
03-23-2019 02:46 - last edited on 04-01-2019 05:31 by YojanaFitbit
Thx. Did all that but nothing worked. Fitbit replaced a couple of weeks ago. I had bought it last October. So far new one going strong. Little cumbersome :alarm_clock: but it works.
Ron
"A creative person is motivated by the desire to achieve, not by the desire to beat others.” Ayn Rand
Moderator edit: Removed personal information.
03-23-2019 13:26
03-23-2019 13:26
Is your Fitbit app set up for the correct dominant wrist? If you have screen wake on auto and the correct wrist selected then call support and get a replacement.
03-23-2019 17:40
03-23-2019 17:40
03-24-2019 11:11
03-24-2019 11:11
Swiping Right does not bring anything up, Swiping Left does bring up the installed apps.
If there isn't another location in the Dashboard or Android app (I haven't found it yet), this does not seem to have a fix.
03-24-2019 11:16
03-24-2019 11:16
03-24-2019 11:17
03-24-2019 11:19
03-24-2019 12:33
03-24-2019 22:13
03-24-2019 22:13
Thanks for this. Problem solved. Do not know when mine got turned to manual. Allan E
03-24-2019 22:55
03-24-2019 22:55
03-25-2019 00:49
03-26-2019 13:19
03-26-2019 13:19
My ionic did not swipe right, but pressing the button on left side of face displayed screen options.
04-01-2019 06:02
04-01-2019 06:02
Hi everybody, thanks for keep posting your Fitbit experience about your Ionic. Sorry for the delay. Welcome to all new members in this thread @segreenwade, @lillex and @MRAP.
@rlfbrew I'm glad to see that finally got your replacement. It's too bad that your old one didn't respond but as you said fortunately you got your replacement. Let us know if you need anything else.
@segreenwade, @Gason and @lillex good to see that your Ionic is working again. Thanks for following those troubleshooting steps.
@Backintm, @AndyB1962 and @Peterkaren thanks a million for the steps that you suggested. It helped a lot of users.
@Star72 I really appreciate the time you took in order to troubleshoot your Fitbit Ionic. Good to hear that it worked for you. Please if you need more help let us know, I'll be glad to keep assisting you.
@tdhandy thanks for following the suggested steps. I noticed that you mentioned in one of your last posts that your Ionic still is not working properly. I've requested a case on you behalf, please keep an eye on your email inbox. Let me know if you need anything else.
@MRAP thanks for reaching out. Please try to restart your Ionic and let me know if this works for you.
I'll be around guys.
04-03-2019 12:32
04-03-2019 12:32
My ionic only swipes one way and that is to display the apps. It will not swipe the opposite way to display that option.
04-03-2019 13:01 - last edited on 04-30-2019 12:25 by YojanaFitbit
Hold left button first
This button also music connection to blue tooth
Regards
