08-29-2018 02:29
08-29-2018 02:29
Have just bought an Ionic and am unable to connect the watch to my home wi-fi network (personal WPA). Have looked at some of the comment streams, and none seem to help.
The watch shows that it is searching for the network, but doesn't connect.
My phone shows that it has synced with the watch, but the watch hasn't actually started (only displays anything when I'm trying to sync with the wi-fi).
Appreciate some help on this.
Best Answer08-29-2018 03:16
08-29-2018 03:16
Is the network you are trying to connect to broadcasting on the 2.4ghz frequency? The Ionic doesn't support 5ghz networks so won't be able to connect to those.
You may find some tips in the following help article.
08-30-2018 11:09
08-30-2018 11:09
If the ionic isn't synced, this could be a Bluetooth issue since thevionic does not sync through wifi.
Have you restarted both the ionic and phone?
08-30-2018 11:59
08-30-2018 11:59
Best Answer08-30-2018 12:26
08-30-2018 12:26
For sync problems on Android,
Restarting the trackerremive the tracker from the phones bluetooth, not the app
Clear the Fitbit cache, once I had to clear the data, but this I did after trying 8-9 other things to resolve the sync issue
08-30-2018 12:47
08-30-2018 12:47
Best Answer08-30-2018 14:46
08-30-2018 14:46
We are not worried about pairing the tracker, which can not be down by the user .
I'm assuming the ionic is still connected to your account. A simple refresh sync should be tried through the Fitbit app.
08-30-2018 15:01
08-30-2018 15:01
Best Answer08-30-2018 15:08
08-30-2018 15:08
I never said that it takes experts 8-9 things to try. I as with most Fitbit users on this community of Fitbit users, we are not experts but simply pass on steps, that sometimes by accident, have been found to help.
If you do want to talk to Fitbit, the contact link maybe found in the upper right corner.
09-05-2018 14:11
09-05-2018 14:11
My apologies Rich, I was thinking that I was dealing with fitbit itself, rather than a fitbit community group. I appreciate your input into helping me resolve the issue. It is still unresolved, but I have taken the watch and my phone back to the retailer to try to sort out. I'll see what their technicians come back with.
Thanks, Norm
