12-11-2019 10:51
12-11-2019 10:51
Since update to 4.1 I am unable to enter water log from watch. When entered in app watch will since and show updated amount. However, when entering with the watch it goes away and does not update to app/server.
12-13-2019 04:50
12-13-2019 04:50
Exactly the same issue. It took me a while to get into this habit of logging water and now the function is useless...
12-17-2019 10:32
12-17-2019 10:32
After latest app update (Android) water logs are syncing however incorrect amounts. For example I log 24 Oz on watch and after app updates it shows. 0.81 oz
12-17-2019 19:20
12-17-2019 19:20
I'm having the exact same issue since the update!! It either goes away and doesn't log at all or it logs wrong... Was watching it today and ionic screen confirmed "44oz logged at 4:03pm"... Then it would refresh and show 1.49oz as my total... Really frustrating. I even tried changing my conversation settings but it wouldn't log 😑
Hope they fix this soon...
12-24-2019 14:00 - edited 12-24-2019 14:03
I have factory reset Fitbit and smartphone. Issue continues to occur. At first it wouldn't log at all, then it would add all the water for several days into one entry. Now after most recent update it logs incorrect amounts. I'll log 24oz of water, Fitbit shows 24oz before sync. After sync it shows .81oz. Weight is also incorrect, Fitbit turned 164.4 lbs into 362.8 lbs.
Last time I reported to Fitbit support they informed me to log using the app not my Fitbit ionic. Sounds to me like they're saying, should have bought a Garmin!
Not happy with Fitbit at all! Perhaps Google will make it better?!?!
Best Answer12-26-2019 20:00
12-26-2019 20:00
For me, issue is now fixed. (the latest android fitbit app update fixed it)
