11-25-2017 08:38
11-25-2017 08:38
I prefer to wear my watches on the inside of my wrist and had some questions about wearing the Ionic this way. Is there any way to get the wake on wrist turn to work when it’s on the inside? I’ve noticed that it only works when worn on the outside of wrist. My previous tracker had the ability to tell it whether you were wearing it on the inside or outside and would adjust for the different movement. Are the sensors less effective when worn on the inside? Thanks!
11-25-2017 13:47
11-25-2017 13:47
@ionicuser9, the main problem with the sensors is that it is designed to turn on the display when the arm is rotated to bring the watch face towards you, to put it in the position to view it in front of your eyes. If it is worn on the inside of the wrist and you bring up the arm and rotate it to view the clock face, it would be rotating away from you instead of towards you.
