10-11-2018 06:32
10-11-2018 06:32
I just noticed last week that the weather on my Ionic had switched ti Celsius. It has always been Fahrenheit. I can't find anywhere to switch it back. When I google it....all I can find is that if you are set on kilometers, the weather will switch to Celsius....but I am set in miles, pounds, etc. Anyone else have this issue? How can I fix it?
Best Answer10-12-2018 06:31 - edited 06-21-2024 11:08
Welcome on board @Earthen, it's nice to see you here!
Have you tried what @WavyDavey recommended?
If you're still having trouble, let's try the following:
10-11-2018 12:20
10-23-2018 11:23
11-30-2018 23:27
11-30-2018 23:27
I had the same issue all of a sudden, it took a lot of Google Fu to find this page.
I had FitBit products from day one, it's sad that stuff is still super confusing. This is where my Series 4 Apple Watch shines .
Best Answer01-22-2019 19:03
01-22-2019 19:03
Wow! Thank you for this clear and easy to follow solution. I purchased my Fitbit Ionic today and it showed Celsius by default. I spent the whole afternoon searching the forum for the solution; none of them worked... and finally I came across yours and it fixed it. I love my Fitbit now. Awesome.
Best Answer09-19-2019 14:47
09-19-2019 14:47
Hello, I'm trying to switch my weather from Celsius to Fahrenheit on my FitBit Iconic but when I go to apps the weather has no settings for it, it just says installed.
Best Answer11-02-2019 23:11
11-02-2019 23:11
My Fitbit weather app is only stuck on one location. It won’t update to ‘current’ location. I have to add other locations as it won’t automatically update. GPS for everything else is fine. Thoughts?
Best Answer03-05-2020 07:43
03-05-2020 07:43
Nope But thanks for trying.
I followed the instructions and they are the same steps that I have always used to try to fix the Fahrenheit Celsius problem. The settings on my app show Fahrenheit and have always shown Fahrenheit. The temperature in my weather app on my ionic always shows centigrade. I have never been able to change it. On top of that, I can’t figure out for the life of me how to get it to remember my city. Every single morning I have to get up I have to get into the app go into the settings and add in my city manually it will not take current location and it will not remember my city. If I don’t do this I get no weather when I click on the Weather icon on my ionic. Is there some sort of magic trick or special set of saving steps that I have to go through in order for it to remember my city or is it that it just is not designed to do so. Also what is the point of having current. Location if it won’t recognize where I am? I go into my settings and I set the location settings to always in hopes that maybe that would fix it at the expense of costing me data and battery life. That doesn’t seem to help either. Thanks for your help.
Best Answer03-05-2020 08:02
03-05-2020 08:02
Hi. Well I tried your suggestion. I went to Google and typed in FitBit.com. It was just a website that describes all of their products. So I thought that maybe what you meant was open the app on my iPhone. No change I make on the app Weather settings makes any difference on my phone. I can’t change the temperature from Celsius to Fahrenheit even though it shows Fahrenheit on the app. On another note, I don’t know how to get the Weather app to recognize my location. I have location settings set to always at the expense. Of battery life and data use. That doesn’t work. I manually type in my city name. I hit edit them done in hopes that it saves it it never remembers it as soon as I get out of the app it gets amnesia and doesn’t remember what I just typed in. Any suggestions for getting this weather app to work? Your help is most appreciated.
Best Answer11-03-2021 09:59
11-03-2021 09:59
Go to Sense
Find All apps
Find Weather
Find Units...place unit you prefer.
Best Answer11-03-2021 10:11
11-03-2021 10:11
Changing temperature units is as follows
Fitbit App => Profile photo => Device photo => Apps tile => Ionic tab at the top => Weather => Settings => Temperature units
Best Answer11-03-2021 11:02
11-03-2021 11:02
