06-26-2018 13:40
06-26-2018 13:40
My phone can find, sync, and connect to my Ionic. However, when I go to update the firmware it says "Searching for your Fitbit Ionic. Make sure your Ionic is nearby."
And it never leaves that screen. It just sits there until the end of time.
I have turned the Ionic off and on. I have turned bluetooth off and on. I have unpaired and reconnected.
I haven't done a factory reset and don't want to. I think that is absurd that you would have to completely reset a device to update it. If that is the only thing I can do to get it to work then so be it.
Best Answer06-29-2018 07:38
06-29-2018 07:38
A warm welcome to the Community @Offroadxj! I appreciate the details you've mentioned and the troubleshoot you've tried.
I would like you to make sure your Ionic is connected to the charger as this can be why it's not finding it. Also, perform the following steps:
If this is still not working, please follow step 2 and 3 as posted in this article Why can't I update my Fitbit device?.
Keep me posted.
