02-03-2018 12:57
02-03-2018 12:57
For phones, I’ve read that it is best to charge at about 50% regularly, then fully discharge about once per month. Is this the same for the Ionic?
Also, how often, if ever should it be shut down?
Best Answer02-03-2018 16:32
02-03-2018 16:32
I let mine go to about 10% before recharging. I've been involved with electronics for over 70 years so I have a little history. You never need to use shutdown unless you are having a problem that a shutdown might solve.
Best Answer02-03-2018 19:02
02-03-2018 19:02
I charge mine from between 15 to 30% depending on if I'm going out and I might run out of charge before I get back home
