04-27-2018 12:51
04-27-2018 12:51
Hi!
Why aren't my exercise(running) settings saved on the watch after I changed them?
Every time I go for a run I have to change miles -> km, what stats to be shown during the run, 1km split and so on. Why aren't the latest settings saved? I think most of us use the same settings 9/10 times, especially the unit setting 🙂
/Mike
04-28-2018 06:10
04-28-2018 06:10
This a known issue that the engineers are working on. Keep your eye on THIS topic, where updates will be posted.
Helen | Western Australia
04-28-2018 06:10
04-28-2018 06:10
04-28-2018 11:06
04-28-2018 11:06
Thx for the reply/info 🙂
/Mike
05-02-2018 07:56
05-02-2018 07:56
Welcome to the Forums @MThor!
Thanks for your patience to this matter, our Team is currently working to get it fix as soon as possible. This fix will be implemented in a future release. As it was explained on the post @NellyG shared in the meantime you may have to input exercise settings periodically.
@NellyG Thank you so much for your assistance!
Catch you later!
09-03-2018 13:20
09-03-2018 13:20
This is back again. It gets corrected and then when they update the software the bug comes back. It just shows that FitBit would rather pay 460 Indians to do the programming instead of two or three good programmers here domestically. This is just poorly managed by FitBit. Makes me want to stop purchasing their stuff.
