02-18-2018 15:35
02-18-2018 15:35
Hi there,
I just noticed that at sleep monitoring, the total sum of percentage is not equal 100% like
Awake 12%
REM 27%
LIght 51%
Deep 8%
So I checked nights before, they were also like 98% too.
Is that normal?
Thanks,
Best Answer02-18-2018 16:51
02-18-2018 16:51
@iamPooh, it is probably rounding errors, and probably related to the issue that the graph at the top of the screen often gives different numbers than if I click on "Benchmark". For last nights sleep stages, for example, the graph shows 13%, 13%, 64%, and 8% (98%) for Awake, REM, Light, and Deep. But, if I click on Benchmark, it shows 13%, 14%, 64%, and 9% (100%) for the same stages. Fortunately, it doesn't make much difference to me.
02-18-2018 16:51
