04-10-2018 17:36
04-10-2018 17:36
I have had my Ionic since Dec 2017. I had previously paired and had been able to use 2 different wireless headsets. As of 2 weeks ago neither pair will connect. I have uninstalled both from my Ionic and have tried to reinstall them both. No go!! I wait till the headphone is ready to pair but when I go to settings/ connect Bluetooth/ add new device all it does is says Searching and then Still Searching. After it will tell me no device detected. What is going on. This is the reason I paid so much money for the watch. (Headphones pair to my iPhone no problem). I want to leave phone behind and just use Ionic for music on my runs. Please help, this is frustrating and driving me crazy!!!
04-11-2018 15:56
04-11-2018 15:56
@Donnagir67 Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing regarding Ionic not connecting to your wireless headphones.
Have you tried restarting Ionic already? This workaround has helped other users in the past:
If for some reason the headphones are paired to Ionic and not working, please unpair them and try the above steps.
Also, when doing the pairing process check if there are any other Bluetooth devices nearby. Other devices may be interfering with the Bluetooth signal, so try putting those devices away to just leave Ionic as the only Bluetooth device around. You can try turning your phone's Bluetooth off while doing this.
Hope this helps. Please let me know how it goes!
04-11-2018 18:12
04-11-2018 18:12
04-12-2018 11:14
04-12-2018 11:14
@Donnagir67 Thanks for your reply and for trying the steps provided.
I went ahead and created a case with customer support in your behalf for further assistance. Please keep an eye on your email inbox for next steps.
Keep me posted!
06-29-2018 15:26
06-29-2018 15:26
I am having the same issue! I just got an ionic and it won’t pair to my wireless headphones. Before trying to pair with my ionic, I turn off all other Bluetooth devices nearby, and put the headphones in pairing mode. I’ve also tried restarting everything. Whatever I do, the ionic can’t find the headphones. I also tested it with a Bluetooth speaker and it wasn’t able to find that either. Can you please help? Thanks!
06-29-2018 20:20
06-29-2018 20:20
07-02-2018 14:27
07-02-2018 14:27
@Kaia14 Welcome to the Fitbit Community! Thanks for reporting the situation you are experiencing connecting Ionic with Bluetooth headphones.
What kind of headphones are you trying to pair? Did you followed these restart steps for Ionic?
Also, please check if there are no other Bluetooth devices nearby that may be interrupting the connectivity.
@Donnagir67 Thanks for your reply and for sharing your experience. I'm glad to hear that you are using some Bluetooth headphones with Ionic and enjoying it.
Did customer support helped you out with your other headphones?
Keep me posted!
07-20-2018 10:47
07-20-2018 10:47
@Donnagir67 What wireless headphones do you have? I am looking at getting a pair, but I want to make sure I get a pair that will work with my Ionic.
