09-22-2018
12:25
08:45
LanuzaFitbit
09-22-2018
12:25
08:45
LanuzaFitbit
I have been having syncing issues since end of July. My ionic won't sync. I am sick and tired talking about pie. I would like to address other issues. Like nit being able to sync no matter what version on android. And nit being able to locate my wifi. My ionic is less than 6 months and won't even give me the correct time.
09-23-2018 08:44
09-23-2018 08:44
Hello @SheWatt.
Let me help you figure out what is going on with your Ionic.
I will be moving your thread to the Ionic board as I think it is better suited for it.
In regards to the WiFi situation, I recommend that you try to read through this article, that should definitely help you out.
In regards to the syncing, I have some questions to ask:
If the answer to the last question is yes, please try to go into that phone's Bluetooth settings and look for your Ionic in the Bluetooth settings. If it is there, please remove it from that list and try to sync again. This would severe the bond between the two that could impede it from syncing with other devices.
Look forward to your reply.
09-23-2018 11:55
09-23-2018 11:55
Best Answer09-24-2018 07:36
09-24-2018 07:36
Hello @SheWatt.
Thanks for answering my questions and letting me know when did this start.
The WiFi connection issue could be happening because of the new modem is running on a different bandwidth. The Ionic will not connect to 5GHz, 802.11ac, I've seen some instances of users having this issue. Do you have access to another WiFi connection you could try?
As for the syncing, let's try to follow the steps in this article. They should definitely help out.
Let me know if you have any further questions.
09-24-2018 11:52
09-24-2018 11:52
Best Answer09-25-2018 07:26
09-25-2018 07:26
Hello @SheWatt.
Please do check on it and keep me posted.
As for the syncing, what phone is it that you are using? What model?
In the meantime let's try to set it up as if it was a brand new device. I've seen several instances where that helps to get it to sync.
09-25-2018 17:15
09-25-2018 17:15
09-26-2018 05:44
09-26-2018 05:44
Hello SheWatt, I have just bought new Ionic fitbit and my device has problem similar like your. I use Iphone 6. IOS 12. Could you pls let me know how to fix it. Thanks.
Best Answer09-26-2018 13:59
09-26-2018 13:59
Best Answer09-27-2018 06:02
09-27-2018 06:02
Hello SheWatt,
Thanks for your help. My fitbit is fixed.
Best Answer09-28-2018 10:07
09-28-2018 10:07
Hello @SheWatt and @thanhpsbkhn.
Thanks for sharing what helped you out with everyone.
We'll be sure to take this into consideration. Thankfully everything seems to be working correctly for now.
If you have the time be sure to visit one of our Discussion boards. Lots of different topics to talk about with other users.
Best Answer09-28-2018 15:06
09-28-2018 15:06
Hello thanhpsbkh,
Can you kindly share what you did exactly to fix the problem? i have an iphone 7 with ios12. How did you download the previous version of fitbit app?
I bought the ionic a few days ago and it just wont sync and i don't know what to do. I had to borrow another phone just to set it up initially.
Thanks!
Best Answer09-28-2018 18:49
09-28-2018 18:49
Best Answer10-01-2018 10:45
10-01-2018 10:45
Thanks for jumping in here @jmasyed! Have you tried what @SheWatt shared with you? Are you still having difficulties syncing your Fitbit?
In the meantime, I'd recommend to see: Why won't my Fitbit watch connect to Wi-Fi? and Why won't my Fitbit device sync?
Looking forward to you response!
