09-14-2019 15:14
09-14-2019 15:14
When I look at my Fitbit it stays dark. It is on, working and charged, but it will not light up when I point it at my face. I thought there was a setting for this but I can’t find it??
Best Answer09-14-2019 15:53
09-14-2019 15:53
Hold in left side button a few seconds; look for 'Screen Wake'; tap to toggle on or off.
09-14-2019 15:53
09-14-2019 15:53
09-15-2019 14:13
09-15-2019 14:13
Fixed! Thank you!
Best Answer01-20-2020 15:05
01-20-2020 15:05
Mine comes up shortcuts and screen wake is not one of the choices
Best Answer01-20-2020 15:33
01-20-2020 15:33
@bydeb1 wrote:Mine comes up shortcuts and screen wake is not one of the choices
You might have reconfigured the left button, which didn't use to be an option. If so, it should be on the screen above clock face; i.e. scroll up (swipe down) from clock, tap on 2 white ovals that show briefly at top to get into Quick Settings. In quick settings, it is the icon of watch with green background.
Best Answer01-21-2020 10:35
01-21-2020 10:35
Thanks it worked!!
