12-29-2018 18:24
12-29-2018 18:24
Brand New Ionic, it will not set up with WiFi to update, have re started fit bit, updated the iPad etc...no luck HELP
 Best Answer12-29-2018 19:47
12-29-2018 19:47
@Cindyyy wrote:Brand New Ionic, it will not set up with WiFi to update, have re started fit bit, updated the iPad etc...no luck HELP
 Best Answer12-29-2018 19:49
12-29-2018 19:49
me too.
 Best Answer12-30-2018 01:36
12-30-2018 01:36
try to set up your wifi manually..
also if you can see your wifi, do it manually.
add new wifi, write the hotspot name and the password and the security type… miine works like hthat at home
