05-01-2018 12:54
05-01-2018 12:54
after the "update" my watch starting having connectivity issues and that my watch was having "Bluetooth issues" after reading about this on the Forum it was recommended to do a hard restart on my watch and uninstall and reinstall the app, which I did. Now my watch only says " go to fitbit.com/setup to get started, which I did and reinstalled the app but still my watch is saying go to the setup app.
What can I do to get my watch working again?????????????????
Best Answer05-01-2018 13:09
05-01-2018 13:09
When you go to setup the watch, it will say “Looking for Ionic” or something like that. If you had all-day sync on, you have to disconnect your Ionic from Bluetooth settings for the phone to actually connect to the Ionic and set it up.
Hope I helped!
Best Answer05-01-2018 13:28
05-01-2018 13:28
thanks for the info, I tried but still no change, it says the same thing on the watch and on my phone
Best Answer05-02-2018 12:23
05-02-2018 12:23
Try doing a restart by holding the left and bottom right buttons down for about 10 seconds.
