02-04-2018 11:27
02-04-2018 11:27
Would anyone be able to tell me where do I find settings to change the clock faces ? I have FlashRing running and the description says you can change the colours - how ?
thanks
Best Answer02-05-2018 04:27
02-05-2018 04:27
wrote:Would anyone be able to tell me where do I find settings to change the clock faces ? I have FlashRing running and the description says you can change the colours - how ?
thanks
@sharenslz In the Fitbit app on your phone, navigate to your account page, select your Ionic, then clock faces, and you should see a little settings cog for the face you have selected. That’s where you’ll be able to change options. Note however that not all faces are customisable and as such there might not be a settings cog displayed.
02-05-2018 04:27
02-05-2018 04:27
thanks
02-05-2018 05:08
02-05-2018 05:08
perfect - all sorted. Help very much appreciated
Best Answer12-31-2018 18:49
12-31-2018 18:49
and if I don't have a smart phone how do I change the face on the Ionic?
