12-17-2017 06:22
12-17-2017 06:22
When I try and download a clock face. it says it needs wifi to work from the watch. The problem is that I cant get the watch to have a strong signal connection to my router. Even if I place the watch directly on the router. my phone connection to the router wifi signal is strong. the watch isn't. I cant seem to get it to work. I've rebooted the watch with no luck. Wifi with this watch has never seemed to work. It had to switch to Bluetooth even when I did the first setup of the watch.
12-18-2017 07:19 - edited 12-18-2017 07:20
@Musictrek Welcome to the Fitbit Community! What clock face are you trying to download? Is it a large one (size)?
Please do the following:
Then, let me know if any of these happens:
Alternatively, as you already restarted the watch, please plug it into the charging cable with a configured WiFi network present (your home, I guess), and try to download the clock face while your watch is plugged in.
Also, could you share a screen shot of the "it needs WiFi to work from the watch" message you are getting?
Keep me posted! ![]()
12-18-2017 08:24
12-18-2017 08:24
Best Answer12-19-2017 07:20
12-19-2017 07:20
@Musictrek Thanks for your reply! Sounds good, please keep me posted with your results.
In the meanwhile you should check the Get Moving Board. This is a board in which other Fitbit users will post a lot of interesting things regarding exercise. Feel free to check all of the Discussions.
Best Answer12-19-2017 15:22
12-19-2017 15:22
Best Answer12-20-2017 08:17
12-20-2017 08:17
@Musictrek Thanks for your reply and for trying those steps. I created a case with customer support for you. Please keep an eye on your inbox for further steps.
Keep me posted!
Best Answer12-26-2017 15:38
12-26-2017 15:38
Having same exact issue
Best Answer12-26-2017 16:02
12-26-2017 16:02
Best Answer01-24-2018 13:44
01-24-2018 13:44
Did there ever come a solution to your problem? I can't connect my new Fitbit of today to my WIFI network too...
Best Answer01-24-2018 15:17
01-24-2018 15:17
