07-25-2018 15:29
07-25-2018 15:29
i am buying an adidas ionic off someone they say it is new just dont have box how do i tell difference between adidas one and regular one ? seeing it isnt connected to an app or set up does the adidas logo come up on screen when powered on ? is there a stamping or something that lets you know which one it is pls help dont want to get the wrong one thanks
Best Answer07-25-2018 16:02
07-25-2018 16:02
There is a watch face with the adidas logo that only comes in this version, there is also an app called adidas coach that can only be downloaded in this version, watchband is blue on the outside and gray on the inside.
Best Answer07-25-2018 16:42
07-25-2018 16:42
yeah it isnt in the box and has like 4 bands that band is one of them but when he turns it on get the screen to go to fitbit.com to set up no adidas logo on that screen
Best Answer07-25-2018 19:54
07-25-2018 19:54
You need to finalize the setup to be able to see if there is the Adidas clockface.
Best Answer07-25-2018 20:15
07-25-2018 20:15
That is correct, after the setup is complete you should see something like this.
Best Answer07-25-2018 20:59
07-25-2018 20:59
Is it an original leather band?
Best Answer07-26-2018 06:37
07-26-2018 06:37
Where did you get that band?
Best Answer07-26-2018 08:43
07-26-2018 08:43
No, it’s not.
Best Answer07-26-2018 08:45
07-26-2018 08:45
Amazon
Best Answer08-03-2018 09:07
08-03-2018 09:07
When setting the Ionic up, you need to tell the Ionic which model that you have.
Choose the Ionic Addidus, if it is not the Addidus the setup will not find the tracker..
Best Answer08-04-2018 03:09
08-04-2018 03:09
Actually once I tried to setup my regular Ionic as Adidas and process went on without any problem, apart the fact that the Adidias version was not installed ![]()
Not sure if a later update changed the things although
